Farmall C Restoration - Mainfold Bolts
Posted by Don Workman on October 11, 2012 at 12:22:25 from (192.234.168.242):
Restoratoring a Farmall C - C133 engine with no water pump (non pressurized). having trouble with small amount of anti-freeze leaking around the manifold bolts that were replaced. Will these seal after a little running time or do I need to remove them and add some sealant to the bolts? The orginal bolts that cam out did not appear to have any sealant on them. If I do need to add sealant what would you recomend?
