Posted by tmiller on October 11, 2012 at 12:36:24 from (205.133.124.88):
Three carb questions for yall if you dont mind helping me real quick...
1.) Farmall f12,F14...Were these IH made carbs or did someone make these for IH like zenith?
2.) Farmall A, B, BN, C, etc...I know zenith and Carter made carbs for these but for some reason im thinking Marvel did too. Is this true? What was the model marvel that they used?
3.) Farmall Cub...Ive seen alot of farmall Cub carbs and they all seem to be stamped IH not zenith or anything did they put anything else on these cubs or are the these just Zenith carbs with a IH stamp?
Im trying to make a carb history document for people at the local show and these are just a few questions i need ironed out.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
