Re: 450 single spline/DUAL spline axles?? ARE THERE 2 KIN...
Posted by RPM1941 on October 11, 2012 at 15:04:35 from (173.23.76.185):
In Reply to: Re: 450 single spline/DUAL spline axles?? ARE THERE 2 KIN... posted by D Slater on October 03, 2012 at 17:04:53:
I wont argue that maybe these were 2 key axles, I just dont remember that detail exactly, the tractors with standard row crop use in the midwest only had 1 key per wheel, I know about the extensions but never seen these in use anywhere. The axle housing difference was as you stated with 2 or 3 machined spot face for the right hand side that replaced 6735D-? on TA tractors. I do know you could swap axle bearings around.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
