Re: pto adaptor-overide
Posted by Brendon-KS on October 12, 2012 at 03:31:51 from (63.245.190.37):
In Reply to: pto adaptor-overide posted by Bill Bowen on October 12, 2012 at 02:58:29:
You're talking about an over-running clutch, I assume? If so, there is typically a roll pin that goes through the cross hole on the PTO shaft that is accessed through the zerk hole. Once you have the zerk and screw on the opposite side out, rotate until the holes and the pin are lined up then drive it out. Probably full of grease so the pin can be hard to find but it's in there.
