Re: Adding Kerosene to Gasoline
Posted by Ron W on October 12, 2012 at 07:57:02 from (216.11.184.78):
In Reply to: Adding Kerosene to Gasoline posted by Va Gasman on October 12, 2012 at 04:45:39:
Well, we used to burn fuel oil in the old farmhouse; converted it to nat gas in 1983. Not having any diesels on the farm, we still had over 500 gals left. I put 5 gals of gas, to 4 gals of diesel, to 1 gal of paper filters used oil. Dump that in the old regulars. I start them on the gas starting tank, and once hot, switch over the mix. Man, do they have power. The trick is you need to have them at RPM, not at idle. I buzz all the firewood, disk, plow, etc. with them. It saves on bucks as those old regulars go through alot of fuel.
