I personally would not put kerosene in anything newer than a Letter series tractor. compression and overall ignition settings of the newer gasoline engines will NOT like it. Kerosene also burns hotter than gasoline, and if the compression ratio is not right, detonation will burn your pistons and valves up in a heartbeat.
With that said, yes, kerosene in a lower compression engine will not hurt anything......remember, there tractors were designed to run "duel fuel", but they had specific configurations such as lower compression ratios, radiator shutters, exhaust manifold redirection butterfly valves, etc. etc etc. An engine designed to run on Kerosene will do just fine, IF up to temp....if not, you will just dilute your oil. Refer to the "dipstick" thread......that is why there were 3 draincocks on the oil pans. Now, if you want to add a quart of oil to a tank of gas, that is a whole other consideration. Many manuals indicate to add some oil to fuel in specific situations, and while you run the risk of fouling plugs if you go overboard, the residual lubrication effects can be beneficial (if you can put up with the additional smoke in the exhaust).
if your tractor is tuned correctly for gasoline, run gasoline in it. While you are not going to hurt anything in the letter or F series doing this, you are also not going to accomplish anything significantly "positive" by doing it (meaning adding kerosene). today's gas runs "cleaner" from a combustion perspective because there is no lead to leave deposits in the combustion and intake/exhaust components. This thread may become hotly contested as it grows, so I have stated my perspective and will leave it at that........
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
