Re: Up date on S/MTA Fuel economy
Posted by The tractor vet on October 12, 2012 at 22:12:13 from (75.24.0.62):
In Reply to: Re: Up date on S/MTA Fuel economy posted by heavyhaulertoo on October 12, 2012 at 19:44:09:
Well i am and OLD time racer also and yes i can do a head i can C/C it i can port it and flow it i can mill it i can install the guides i can install new seats and put bigger valves in . It still will get HOT when your working it if it looping along and the gov. is not holding the butterfly wide open then it is not going to get hot . When your going down a hill or on flat ground even with 3x16 behind mine she will not glow the manifold But you put her on the pull up a 1/2 mile long field she sure will when the gov. opens up and she stays wide open . And yes i can get more if i want to spend money on her i can and have two S/MTA's that i did for guys years ago that have a lot more then mine has . If i need more then we got the 706 if that is not enough then the 806 comes out if that is not enough then the 1066 comes out and if that is not enough then the 2255 comes out . After that well we are out of luck .
