Re: another stupid 12 volt question
Posted by JerryU on October 18, 2000 at 04:37:24 from (204.39.45.3):
In Reply to: another stupid 12 volt question posted by Tom W. on October 18, 2000 at 03:52:25:
I assume we are referring to a common Delco 17si Alternator. These are the ones with a big terminal on the back and two little ones on the top. The big one on the back is the charging terminal and can be run via #10AWG wire to the battery or any cable that connects to the battery. The #2 terminal-right on top as you look at it from the back is a voltage sensing terminal and can be jumpered to the Bat termianl above. Finally, the #1 terminal-left one- is the exciting terminal. It needs to be connected to a source that is on only when the iginition is on or you will drain the battery, i.e. coil lead from ignition switch. It needs either a resistor, diode, or sidemarker light hooked into it or you tractor, once started, will not shut off. Only other way around it is to get a "one wire" alternator. I would do the #2 jumper and put a light in the #1 wire and run it to the coil (ignition switch side). Also the light will tell you if it is charging properly. JerryU
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
