Posted by BigTone on October 13, 2012 at 14:44:10 from (70.192.0.4):
Just went to start the M, hit the starter button and it turned over but refused to fire. Tweeked a couple things, hit the button, wouldnt fire. I had oil dripping from the spot where the oil gauge goes into the block (didnt tighten enough) so I have oil circulating, hooked up my spark tester, hit the button and the shocked i took almost put me on the ground so I have spark. I turned the gas off, took out the drain plug and no gas came out and I do have flow through the gas line. I took the bowl off, cleaned everything again, reset the float to 1 5/16" like the manuel said, put it all back together and still no gas going to the carb. am I setting the float wrong? the book shows the measurement with the float level.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
