The book called for 140 wt gear oil and It is out there, but may be hard to find. it will boil down to having oil jobbers makeing some calls but you will find it. Keep filling through plug at top in front and it will fill all the "tubs inside and it makes its way to the back. When it runs out the back it is full. I used 30wt motor oil in mine and it ran just fine even starting it by hand crank in cold weather. I buy 2 gallon jugs and open the lower valve and the top one on the pan. When it comes out the lower one shut it off and you will know it is getting close to filling up. When it comes out the top valve it is good. Sure does look good! I remember when you posted that you found it!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
