Re: 354 clutch with pics update
Posted by jimb2 on October 13, 2012 at 19:16:24 from (99.241.38.122):
In Reply to: 354 clutch with pics update posted by steven in tn on October 13, 2012 at 12:39:44:
Hi Steven,
From a post by Bernard le mecano:
Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to aling the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then presure plate, belleville spring and cover. Aling all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job. Bernard le mecano
Hi, yes you can, if you don't change the PTO clutch. If so, make sure to center the PTO clutch in the pressure plate before fastening the finger bolts. Re-gap the 3 bolts to .090 inchs for the PTO plate. Bernard le mecano
Hope this helps
JimB
