Re: diesel issue....
Posted by jimb2 on October 13, 2012 at 19:42:31 from (99.241.38.122):
In Reply to: diesel issue.... posted by John in Pennsylvania on October 13, 2012 at 18:08:59:
Hi John,
This was posted some time ago:
I also just rebuilt a BD154. I might note that the timing gear marks can be a bit deceiving due to the idler between the crank gear and the injection pump drive gear. Mine runs really nice. Fires right up after using the glow plugs when cold, but after she is warm, it takes right off.
Been a while since I've timed a CAV/Lucas injection pump, bear with me. If you pull the rectangular cover off the side of the pump (held on with 2 small bolts) you will see the side of the cam ring. It will have a scribe mark on it the you can see move in the window as you turn the pump drive shaft. When that scribe mark lines up with the square end of the snap ring holding the cam ring in the pump body, the pump will be at start of injection. You need to know the static timing mark used for setting start of injection, usually either marked on the flywheel or front pulley, not sure on a 414, but on many engines it is right at TDC. Rotate the crankshaft in the direction of engine rotation, (to take up any lash in the timing gears) until the engine timing marks line up, with #1 cylinder on top of compression stroke. At that point match the marks in the pump and lock her down to the front plate. Turn the crankshaft back 45 degrees and bring it forward again and recheck both sets of marks. Readjust if needed, re-install window cover plate and bleed pump. Guessing on fuel pump timing and getting too much advance can be fatal to the engine if it is expected to work hard. I refuse to use the external scribe marks on the pump and front front cover, seen them out by over 1/8 inch on a regular basis.
Hope this helps.
JimB
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
