Posted by mkirsch on October 14, 2012 at 08:37:40 from (67.253.161.186):
In Reply to: Charging posted by KTNC on October 13, 2012 at 17:57:46:
Is it a VOLT meter or an AMP meter?
What does the face of the gauge say?
Farmall M's came from the factory with an AMP meter, but that could have been changed to a VOLT meter.
An AMP meter would stay in the middle only if the tractor is off. When you turn on the ignition and/or lights with the engine off, the needle should move to the left. When you start the engine, the needle should move to the right.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
