Re: farmall 460 stuck in gear
Posted by DeltaRed on October 14, 2012 at 10:16:37 from (67.6.219.50):
In Reply to: farmall 460 stuck in gear posted by Joshua Ratliff on October 14, 2012 at 10:08:50:
Jack up a rear wheel to remove 'pressure',pull the TA lever back a couple times ,then leave it back.That should relieve pressure on the gears,allowing you to 'shift'
