Re: Farmall BN: Positive Ground?
Posted by TractormanNC on October 14, 2012 at 12:28:12 from (108.72.58.200):
In Reply to: Farmall BN: Positive Ground? posted by spf150 on October 14, 2012 at 12:12:36:
Originally was 6 volt POSITIVE ground. Who knows what has been done in the past 60 plus years.
With that said, if it is still 6 volt, positive ground is correct but it will work either way. Just be sure to polarize the generator before starting.
If converted to 12 volts with an alternator, then it needs to be negative ground since most alternators are negative ground.
