Re: Farmall BN: Positive Ground?
Posted by old on October 14, 2012 at 12:30:50 from (209.86.226.19):
In Reply to: Farmall BN: Positive Ground? posted by spf150 on October 14, 2012 at 12:12:36:
Factory it did come out as + ground and if it is still 6 volts and has a generator on it then yes it should be + ground. As for hooking it up the other way most systems do not care which way you do it as long as you polarize the charging system after you install a battery. So did you hurt any thing you have say a 99% chance all is just fine
