Re: h running temp
Posted by gene bender on October 14, 2012 at 16:24:24 from (67.55.227.68):
In Reply to: h running temp posted by Tuckermac on October 14, 2012 at 14:54:53:
You need to work it heavy like pulling a plow to get it before the temp guage will move. Just take the old sender and put it into some hot water using a therm to get a reading on water temp then compare what the guage says. Have you placed a therm in the radiator when its running. You can even use a mitch to warm the sender up to get the needle to move.
