Re: Farmall 200 and FH Cycle mower adjustment
Posted by wolfman on October 14, 2012 at 18:16:27 from (174.140.65.158):
In Reply to: Farmall 200 and FH Cycle mower adjustment posted by Dean Olson on October 14, 2012 at 15:01:13:
Looks like your sway arms are to the right-which is actually good. Mine, due to wear & tear and slop, lean to the left just a tad even tho pinned. This left lean tilts my mower the wrong way both for lift and for tip-of-the-cutterbar lead. Looks like you want to concentrate on the actual lift arm (behind right tire in pic). Mine is higher when rock shaft pulls long rod forward, a good bit higher. I have found it helps to put a light chain from left side of mower frame to right axle of tractor
