Posted by Rod51M on October 14, 2012 at 18:35:15 from (71.254.123.42):
In Reply to: heat housers posted by Joshua Rod on October 14, 2012 at 18:27:05:
We had one for our M. Basically just a wind-break with a little heat coming back, but when the wind was behind you, you froze just the same. I would say it was better than nothing, but not much. Ours was in pretty bad shape so I can't speak for how they work when new/good shape.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
