Posted by Heat Houser on October 14, 2012 at 18:57:26 from (69.66.35.73):
In Reply to: heat housers posted by Joshua Rod on October 14, 2012 at 18:27:05:
Hey, I live in Iowa and have a Femco for my 4010. Wouldn't do a winter without it. My 4010 is a gasser so it may be a bit warmer than a diesel but the harder you work them, the warmer you get. My 4010 is the loader tractor so I use it to feed silage, feed round bales, and to move snow. Yes if the wind is directly from the rear you may get cold but it is worse without any protection. The first winter I farmed, only made it to January before I bought one and installed it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
