Re: heat housers
Posted by Janicholson on October 14, 2012 at 21:53:58 from (96.24.99.126):
In Reply to: heat housers posted by Joshua Rod on October 14, 2012 at 18:27:05:
I will add that putting some cardboard over the radiator will dramatically improve the heat flow. In 30degree conditions as much as 50% can be covered. The heat gauge should be at least moving toward run. They do make a difference that is worth it, especially if plowing snow, or doing farm routine feeding manure etc. Layer your clothing so you never get cold. Mickey Mouse Boots are a real advantage. Jim
