Re: broken starter nose cone
Posted by gene bender on October 14, 2012 at 22:25:06 from (67.55.227.68):
In Reply to: Re: broken starter nose cone posted by tom dowling on October 14, 2012 at 20:10:33:
Yes the nose cone is on the pressure plate side better fish it out before it gets into the pressure plate and flywheel starter gear. What makes you think its not on the pressure plate side
