Posted by steve_in_mo on October 15, 2012 at 08:54:20 from (168.166.54.11):
In Reply to: heat housers posted by Joshua Rod on October 14, 2012 at 18:27:05:
Used to run a 1951 Farmall M with a heat houser on it when I was growing up. We had livestock and crops so the tractor got used all year. The heat houser made a lot of difference.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
