Re: Fluid Change
Posted by Bob M on October 15, 2012 at 13:01:44 from (74.67.191.50):
In Reply to: Fluid Change posted by KTNC on October 15, 2012 at 08:45:27:
Tip: If the transmission is full there's 13+ gallons of dirty oil that's gonna drain out when you pull the plug! So before you start have at least three empty 5 gallon buckets immediately at hand.
I've never bothered to flush out a rear end. However some people recommend dumping in about 10 gallons of diesel or kerosene. Then drive the tractor gently (no load) for a few minutes to circulate the diesel/kero.
