Re: Fluid Change
Posted by glennster on October 15, 2012 at 13:04:31 from (75.57.134.154):
In Reply to: Fluid Change posted by KTNC on October 15, 2012 at 08:45:27:
as far as the rear end grease, any 80-90 wt will work fine. even the 80-140 wont hurt either. it holds about 14 gallons. it can hold also several gallons of water too. have about 4 or 5 empty 5 gallon buckets handy for draining. if you want to do a little flushing in advance, add 2 gallons of kerosene to the rear end, then toodle around for a couple days to loosen all the gook up. pull the rear plug first, be careful not to drop it, (dont ask) if nothing comes out, probe with a wire or screwdriver to break up the goo. let it drain out, then pull the second plug under the tractor, forward of the rear plug.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
