19?? WA 40 info?
Posted by D21Smithmm on October 15, 2012 at 19:04:33 from (50.140.164.140):
third party image
stumbled into a what i believe is a WA40 today and brought it home with me. the serial# is wac1130. the tractor appears complete. manifold is perfect looking which i figured was probably unusual. motor is loose and mag has spark after filing the points. oil appears clean and had antifreeze int radiator. any input as to where to get a carb kit? also rear drawbar is held in place witha a turnbuckle type setup? didnt know if this was right or not? also the brake handle has been broken and a piece of pipe has been cobbled up( didnt know if there was another model with the same handle?) rear tires are 36" which are rough and junk wheels. any other choices? sorry for all the questions im just new to these old brute tractors. After i have tractor running any idea to the value of the tractor? thank you for any and all help and information..
