Would have to know what engine and situation. I have seen many gasoline engines with broken top rings when they ingested dirt, wore out top ring and piston groove then ring busted. Detonation, preignition, will do it. If it was rerung, badly worn top ring grooves, cylinder ridge not cut properly could do it . On a diesel, excess ether usage, over fueling etc. Even too little end gap of rings. Many causes.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
