Posted by Janicholson on October 15, 2012 at 20:50:07 from (96.24.99.126):
In Reply to: Farmall H tranny gears posted by mschwartz on October 15, 2012 at 20:01:06:
If all gears includes 5th, the drive coupling in front of the trans, (not in it) could be coming apart. It has the look of a U joint, but when bad makes noise. I think you could see it through the inspection plate just behind the Belly pump. If 5th is knock free, it could be a chipped tooth (or broken) on the constant mesh gear, or a bad front input bearing. Look at the coupling first. As far as I know the gears will interchange as a whole set. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
