Re: push-pull switch won't shut tractor off
Posted by Janicholson on October 16, 2012 at 09:47:21 from (199.17.6.160):
In Reply to: push-pull switch won't shut tractor off posted by BruceS. on October 16, 2012 at 09:40:43:
Pretty l;ikely that the switch is not grounded. Use a jumper from the switch button to a clean metal surface then try it. Also try grounding the terminal right at the mag. If that does not kill it the wire from the points to that terminal is off. Jim
