Re: M Farmall Air Filter
Posted by The Red on October 18, 2000 at 15:08:21 from (12.75.197.180):
In Reply to: M Farmall Air Filter posted by Tis on October 18, 2000 at 13:41:50:
Tis the M has an oil bath air filter assembly on the carburetor side. The bottom of the air filter has a cup which holds the oil. You will see a threaded eye bolt you must loosen up in order to remove the cup. The guts of the air filter is an aluminum mesh.
Post A Followup
: Re: Re: M Farmall Air Filter
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
