Re: Questions about 656
Posted by John G. Hasler on October 16, 2012 at 16:42:38 from (174.124.54.72):
In Reply to: Re: Questions about 656 posted by Randy in penna on October 16, 2012 at 14:31:46:
You need to tear down the entire shifter linkage, bore out all the holes in the links, and install oversize pins (or install bushings in the links and replace the pins with the same size). Note that the pins in the final link (the one that connects to the bar coming out of the transmission) are supposed to be welded in. You may also need to replace the plates in the gate mechanism. You can make them if you have patience and a Dremel. It"s a nice shifter when it"s working right, and it is very nice to have a clean deck.
