Re: rear tires
Posted by sflem849 on October 16, 2012 at 17:52:15 from (69.197.84.39):
In Reply to: rear tires posted by carlsandberg on October 16, 2012 at 17:38:08:
That is not entirely true. 12.4 vs 13.6 vs 14.9 vs 15.5 all have a different height. As for hard on differential gears...then so is turning. I suppose it could accelerate wear. It isn't like they are "locked in" when you are going in a straight line. Even a pound difference in air pressure would make the differential spin at different speeds. Heck, if that is true you couldn't moldboard plow because the furrow tire slips more than the land tire.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
