Re: fast hitch problem
Posted by NoNewParts on October 16, 2012 at 17:55:21 from (67.240.145.25):
In Reply to: fast hitch problem posted by Danny Hogge on October 09, 2012 at 20:43:44:
I also believe the remote valve is leaking.
This statement:
sounds like your cylinder is ok
my setup bypasses the factory hydraulics completely.
(block off plate under the pipes with only a pump suction hole drilled)
just pump, to a open center remote, to the cylinder,
with the valves return plumbed to factory drain plug location.
no check valve under the seat, and no stop plug on the cylinder.
(it was missing, so I brazed a pipe plug in the hole.)
works fine, doesn't leak down
heavy loads, I just move the lever slowly down
