Re: 140 ring gear turning on flywheel
Posted by Phil Tibbetts on October 16, 2012 at 18:21:54 from (208.93.14.38):
In Reply to: 140 ring gear turning on flywheel posted by Mitch in NC on October 16, 2012 at 15:24:01:
I'd go with the locktite provided the ring gear is not cracked. First I would tap the ring gear away slightly and then apply some locktite primer to make sure it is perfectly clean. then put the locktite to it and tap the ring gear up against the flywheel.
