Re: 140 ring gear turning on flywheel
Posted by TWheat on October 17, 2012 at 03:56:13 from (74.4.69.181):
In Reply to: Re: 140 ring gear turning on flywheel posted by Mitch in NC on October 16, 2012 at 15:51:02:
I don't know if the bell housing is the same as a Super A as far as the hand hole inspection location, but on my Super A , I took the starter off, took off the hand hole plate, I used a piece of steel stock connected to the welder ground cable thru the hand hole and my friend welded it thru the starter hole , I think 6 evenly spaced welds.. Works fine so far.
