Re: rear tires
Posted by NoNewParts on October 17, 2012 at 04:16:03 from (67.240.145.25):
In Reply to: rear tires posted by danmcdonald on October 16, 2012 at 15:30:53:
pull it onto a hard surface, and use air pressure differences
(within reason)
to make the height close, and run em
on 3 of my tractors with matching tire sizes and wheel widths,
but different brand tires per side, the tire heights aren't even close.
one with 12.4-38's is so obvious, seen from a distance, you think
it's getting a flat tire.
I don't drive on pavement, so I don't worry about it.
sflem849....run into the same problem here.
hard clay, have to have a little moisture in it, or
you can't pull anything thru it.
When a little damp, the clay is so slick, the furrow tire
is always spinning
