Re: 140 ring gear turning on flywheel
Posted by Plant Doc on October 17, 2012 at 07:10:38 from (71.168.251.124):
In Reply to: 140 ring gear turning on flywheel posted by Mitch in NC on October 16, 2012 at 15:24:01:
Are you sure there is not a problem with the starter drive? Generally if the ring gear is as loose as you are describing, you can reach in with a pry bar and and pry the ring gear off the flywheel. This is what I would do to check the ring rear. I suggest you remove the starter and replace the starter drive before getting into splitting the tractor to get to the ring gear.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
