Re: 140 ring gear turning on flywheel
Posted by rustyfarmall on October 17, 2012 at 08:56:40 from (67.55.162.174):
In Reply to: 140 ring gear turning on flywheel posted by Nebraska Kirk on October 16, 2012 at 15:32:34:
Actually, the correct way to install a new ring gear is to heat it up so it expands, and then lay it down on the flywheel in the correct position. When the ring gear cools, it will be tight on the flywheel. Some folks just put the new ring gear in the oven at about 450° for several minutes.
