Re: 140 ring gear turning on flywheel
Posted by El Toro on October 17, 2012 at 09:17:51 from (108.3.143.30):
In Reply to: 140 ring gear turning on flywheel posted by Mitch in NC on October 16, 2012 at 15:24:01:
You may be able to find a good used flywheel with a good ringgear. Other models may use the same flywheel. Then you can take a good look at the clutch disc to see if needs rebuilding. I had a brake shop to reline the clutch disc from a Farmall A. Hal
