Posted by Janicholson on October 17, 2012 at 18:33:44 from (96.24.99.126):
In Reply to: 340 PTO clutch posted by FlipRutledge on October 17, 2012 at 16:16:20:
If there is any wear or lost motion in the linkage (at all) the adjustment will be off. (way off in some cases) (reprint from prior post of mine): The linkage on well used PTOs on these become dysfunctional after years of use. Two suggestions: Make very sure there is no lost motion in the hand lever pivot and rod mechanism. Be certain the hand lever moves the PTO lever from the middle both ways. Adjust it like this, after there is no play in links. Move the lever exactly half way between the locked on position and locked off position (little flipper catch on lever. Take off the little dome metal cover from the adjust screws. Peanut shaped on the top of PTO. Loosen the jamb nut, and tighten the front (away from you) screw until it is just a bit tighter than the point at which it begins to feel tighter as it is screwed in (maybe a eighth turn) then back it off until the PTO shaft will turn with least drag (about 3/4 turn out) and tighten the lock nut while holding the adjuster. Do the same for the closer (brake)adjuster. If the screws go into the jamb nuts and get flush with the top surface of the nut, the bands are probably worn out, and may be operational for a while, but plan on a rebuild. Now (tractor off) push the the lever down toward the brakes. As it goes down, it should get harder to push when it is about 4" (or so) away from fully OFF. and be noticeably harder to push for the last inch, but not real hard. (this is the brake band tightening on the drum in the PTO unit. Then pull it up and do the same feel. The ON position should feel the same way. The shaft should turn pretty free when the lever is half way, and not at all when in either ON, or OFF. (tractor shut off) If it slips now, it needs a rebuild. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
