Re: 300U Dies
Posted by Janicholson on October 17, 2012 at 18:45:09 from (96.24.99.126):
In Reply to: 300U Dies posted by Zonie2 on October 17, 2012 at 07:29:38:
If fuel is getting to the carb (constant stream for 2 minutes or so) and if choking it doesn't help at that point, ignition is where to look.
Points adjustment Distributor bushing wear (no side to side play should be felt at all, .001 max looseness) points adjusted to .020".
and still no joy, a new condenser is next. then a new coil. Do not replace more than one thing at a time. When it has a fat blue 1/4 inch spark that is no longer an issue. Jim
