Re: push-pull switch won't shut tractor off
Posted by cchigg on October 17, 2012 at 18:52:22 from (76.118.14.146):
In Reply to: push-pull switch won't shut tractor off posted by BruceS. on October 16, 2012 at 09:40:43:
Try taking the wire off of the mag and put a test wire on the mag long enough to reach the base of the spark plug. With the tractor running touch the wire to the base of the plug. The tractor should stop. If not check inside the mag for the wire there.Mine was a dirty ground at the push pull switch.Good luck
