Posted by The tractor vet on October 18, 2012 at 12:18:56 from (75.24.0.62):
In Reply to: SH Tire Ballast choice posted by Va Gasman on October 18, 2012 at 10:29:01:
I have had tractors for the last 45 years and only three do or did not have cal. in the tires . One was my 450 D , it had cal. in the tires till i got this hair brain idea that i was going to pull it and had to drain them to make the 6500 lb class . That was all fine and dandy till i hooked to the four bottoms and sat there spinning . Ok lets hang two sets on her - no lets add two more sets of weights to it , oh gee still don't have enough even with the traction boost handle all the way up lets put two more sets on her maybe i'll put one more on the land side that will do it ah one more set yep thats got it , Dam broke off the neighbors fence post from the weights hanging off the left side . and all that work hanging weights got old real fast . I have never owned a new tractor and ihave never had a perfect tractor i always get someone's else's throw away If the tire is leaking fluid then fix it and clean up the rim and go on . If you are to lazy to either break down and fix a tire get someone to do it for you . Takes years to rout out a rim . Around here on our hills you want all the weight on the tire you can get . Our one 706 that Eugene own's does not have fluid in the tires and just the Haybine will shove you down a hill or sideways on a hill . If you are just playen with it and hauling it to shows and such then don't load the tires.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
