Re: Lower bolster diassembly for 'M'
Posted by IAtractorKid on October 18, 2012 at 17:42:39 from (216.81.154.234):
In Reply to: Lower bolster diassembly for 'M' posted by Patrick HMD on October 18, 2012 at 17:23:19:
No need to take radiator off as that wont gain you access to the heads of those 4 bolts. Scrape away all the extra grease and you can see the heads up in the bolster from the bottom side. turn the front wheels 45 degrees one way and you can get at opposite two bolts with an open end wrench then turn 45 degress the other way for the last two. Never had one those bolts that didnt spin without a wrench on the head.
