Re: 140 ring gear turning on flywheel
Posted by Mitch in NC on October 18, 2012 at 18:32:16 from (174.106.112.216):
In Reply to: 140 ring gear turning on flywheel posted by Mitch in NC on October 16, 2012 at 15:24:01:
Just wanted to thank you guys once again for all the ideas and advice. Here's what I did to fix the problem....
The ring gear was loose enough to turn very easily, but I never found a crack even after checking it slowly with a bright flashlight. I really didn't think the fit was tight enough for any loctite to hold it, and I am very familiar with the grades of loctite as I have built transmissions, axles and t-cases for large trucks for the last 14 years.
The more I thought about it, the more I realized my tractor had been getting harder and harder to start over the last few months. No wonder...the ring gear was spinning on the flywheel and the crankshaft was hardly turning, but I never noticed it until it just wouldn't crank at all. It sounded like it was cranking, just not firing right up like it should.
Well, since the teeth were still in great shape, I had my welding fix-it buddy to come by and we tacked it in 6 different spots. He charged my $25, but I gave him $30 for coming right away. I put the starter back on, which I had just had rebuilt a couple of years ago, and that bad boy fired up as soon as I hit the key. It had been a long long time since it cranked that quickly.
So, it is true, some stories do have happy endings, and this is one....thanks to you guys.
Now I have 4 "F"s to be thankful for...my faith, my family, my freedoms.... and my farmall.
Mitch in NC
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
