Posted by Janicholson on October 18, 2012 at 21:28:39 from (96.24.99.126):
In Reply to: farmall 400 motor posted by alex t on October 18, 2012 at 20:36:28:
Put them in, and set the crank so that #1 is almost up. Put a used head gasket on the block, turn the head over and put oil based modeling clay on the edges of the combustion chamber, but wthin the area of the gasket. Set the head in place and put the head bolts in but leave them 1/8 inch loose. Turn the fan by hand, or crank, or raise one wheel and put it in fifth. This allows the engine to be turnd carefully through one revolution. If the piton raises the head, stop. if not they will deform the clay such that you will be able to see the clearance where the head comes close to the popup. Usually .060", to.080" is plenty. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
