Re: Pulling front bolster on M
Posted by markalayne on October 19, 2012 at 05:05:52 from (97.73.64.145):
In Reply to: Pulling front bolster on M posted by markalayne on October 16, 2012 at 09:11:11:
Finally discovered the problem with my M. The cam gear nut backed off. Cam key way wallowed out. Teeth on gear half gone. I guess the geared moved forward to a point where it started to rub against cover and then broke off the forward half of the teeth. Question today is: The cam has about 1/4 inch "run out"? I can move it in and out with my hand. Normal? Seems excessive to me. Valve train movement seems normal so I believe cam is not broken. Will check more thoroughly later.
