Low oil pressure on M engine rebuild
Posted by Iamarv on October 19, 2012 at 05:40:31 from (166.181.3.62):
I recently did an out of frame rebuild on a Farmall M engine. Plastigage was used on the main bearings to ensure proper tolerance. Oil pump has been inspected and refirbished. I'm getting good oil flow to the head but very little coming out of the L shaped fitting coming out of the block where the oil line is attached. Is it a cam problem? Are the rod and main bearings getting sufficient oil? Help is needed!!
