Re: H charging problem
Posted by Janicholson on October 19, 2012 at 09:27:34 from (199.17.55.159):
In Reply to: H charging problem posted by LonM on October 19, 2012 at 08:55:17:
This will make it work. If all grounds are good, and the wire from the light switch to the F terminal is no longer being used (it is not needed with a VR) the answer should be within these procedures. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
