Re: starting problems
Posted by Janicholson on October 19, 2012 at 13:15:39 from (199.17.55.154):
In Reply to: Re: starting problems posted by susan4856 on October 19, 2012 at 09:27:50:
There are various alternators that can (and have been adapted to Tractor use. Giving generic repair informtion doesn"t work. If it has an external voltage regulator, and says Delco on it or the regulator, It is likely a delcotron. If it has an internal voltage regulator, or isn"t Delco, we need a picture. The cheapest and most reliable solution (if it is not a 10SI series Delco internally regulated Alt, is to put one on it. A Hitachi Alternator from a 1986 Nissan PU. is a good fit and smaller than the Delco.
w.cngco.com/ (Carter and Gruendwald) also provides diagrams for later tractors. The Hitachi wires the same as the Delco. The L terminal = terminal 1 on the delco. The S terminal = #2. My recommendation is to go with the diode suggested in the Bob M diagrams. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
